MOPARHOTRODS
going to build a 383 for my dart looking for some information on heads what would be the best head to run and what is the CC volume on the 67 915 440 HP heads and the 906 heads any help appreciated thank you
please does anyone out there have the information I seek what are the cc for 2780 915 heads and the 906 heads thank youLast time I had a set of 906 heads rebuilt the final bill was $1500. I could've saved money and had more performance and less weight with aluminum heads.
thank you sir for the informationstock 915 heads are about 79cc, stock 906 about 89cc.
yes, this is why a vendor at the last little mopar swap I was at had 8- 10 pairs of stock BB heads, all for $100 TOTAL! no joke. he hauled them home? lolGo stealth heads.. 2.14"/ 1.81" valves, slightly larger ports, 80cc chambers, and oh ya aluminum.. the only way a purist will be able to tell it is an aftermarket head is the head bolts - they use ARP style reduced head bolts/studs
I wouldn't waste my time on Iron heads- you'll have $500 in machine work in them and that's the cost of 1 assembled stealth head.. spend $1,000 on the heads, and $500 or so having them checked out/setup.. you'll be miles ahead - plus 50lbs of weight off the front end!
