Building up my swinger
Small Block Mopar Engine
  1. james Farner
    james Farner Member
    9
    7
    May 27, 2017
    San Dimas
    Local Time:
    4:51 AM
    I have so many questions about building my swinger up from a 225 to a 318.. for now. For the rear end, people tell me to buy 8 1/4 or just change the gears in the 7 1/4 i have now. how do i know what gears to change to, and if i should do that?
  2. stixx
    stixx FABO Gold Member FABO Gold Member
    526
    300
    May 30, 2006
    Southern Germany
    Local Time:
    12:51 PM
    For starters you need to know what rear end ratio you have now and whether you can live with that. The 7 1/4 might be just fine behind a 318, very much depending on what you are planning to do. A 8 1/4 will be stronger... but again we need to know your plans. Mild 318 or more performance oriented? When you tell us your plans people can give recommendations on the rear end, but then I would not start this build with changing the rear end. :)
    Also have a look in the "How to"-section or use the search function to look for /6 to 318 conversions...
    • Like Like x 1
    • dartfreak75
      dartfreak75 Well-Known Member
      2,358
      1130
      Aug 10, 2011
      Virginia
      Local Time:
      7:51 AM
      I picked up a 8.8 ford out of an explorer for 100$ bucks pretty cheap conversion super strong and has disk breaks.
      • Like Like x 1
      • nm9stheham
        nm9stheham Well-Known Member
        9,930
        2311
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        7:51 AM
        OP, what are you going to use the engine/car for? If you are going to always do mild cruising up and down the highway, then the 7-1/4" will work fine. If you are going drag racing, then it will break.
        The same applies for gears: What is your use for the car?
        • Agree Agree x 1
        • nm9stheham
          9,930
          2311
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          7:51 AM
          And here is a video of finding the tag on the rear axle that tells you the rear gear ratio.
          If that is missing, then you can jack up one side of the rear axle off of the ground and do the following:
          Hint: The above video is for an 'open' rear axle (not a SureGrip or posi-trac type), which is what your /6 car likley has.
        • dartfreak75
          2,358
          1130
          Aug 10, 2011
          Virginia
          Local Time:
          7:51 AM
          If it's a slant 6 car it's more than likely 2.76 gears.
        • rumblefish360
          rumblefish360 so close yet so far away
          33,434
          5498
          Jun 21, 2005
          New York, on a Island
          Local Time:
          7:51 AM
          What is your goal for the engine and car?
        • furrystump
          furrystump Well-Known Member
          592
          327
          Nov 13, 2004
          Local Time:
          12:51 PM
          not to hijack, but where does the 8.8 fall in durability compared to the 8 3/4 and the dana 60?
        • kursplat
          kursplat FABO Gold Member FABO Gold Member
          1,039
          266
          Aug 24, 2010
          so cal
          Local Time:
          4:51 AM
          seat of the pants analysis: 8 3/4 = 8.8 for durability. dana 60, there's a reason they put them behind hemi 4 speeds
        • james Farner
          james Farner Member
          9
          7
          May 27, 2017
          San Dimas
          Local Time:
          4:51 AM
          My goal is to just have a performance vehicle and take it to the drags occaisionally. just want a strong performance for street and drags. Nothing too wild because im on a low budget. thank you for replying.
          • Thanks! Thanks! x 1
          • james Farner
            james Farner Member
            9
            7
            May 27, 2017
            San Dimas
            Local Time:
            4:51 AM
            thank you so much, this helps me alot.
          • james Farner
            james Farner Member
            9
            7
            May 27, 2017
            San Dimas
            Local Time:
            4:51 AM
            ill check it out but im sticking striclty to dodge parts as much as possible. but thank you for the reccomendation. ill keep it in mind.
            • Agree Agree x 1
            • james Farner
              james Farner Member
              9
              7
              May 27, 2017
              San Dimas
              Local Time:
              4:51 AM
              My goal for this car is to eventuallly modify it to a bigger small block and enjoy the build up such as starting off with a 318. I want a neck breaker, show car, and something im not afraid to let rip. take it to the drags. thank you for asking.
              • Like Like x 1
              • dartfreak75
                2,358
                1130
                Aug 10, 2011
                Virginia
                Local Time:
                7:51 AM
                Yes I understand completely I didn't want to either but after seeing all the prices for 8 3/4 and with my budget I dont see any other options
                • Agree Agree x 1
                • james Farner
                  james Farner Member
                  9
                  7
                  May 27, 2017
                  San Dimas
                  Local Time:
                  4:51 AM
                  im usung low budget because im only 18, not much money to make with no experience ha
                  • Like Like x 1
                  • dartfreak75
                    2,358
                    1130
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    7:51 AM
                    We've all been there buddy read alot there is alot to be learnt here lots of knowledge search read post ask questions thats what I do!!! Lol work hard save up as much money as possible your gonna need it lol good luck to you remember ask lots of questions and learn! Knowledge is power!
                  • dartfreak75
                    2,358
                    1130
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    7:51 AM
                    Oh and btw if the slant 6 is still in the car and running they can be made to be neck snappers! Don't rule out spending the money on it! By the time you buy your 318 or 360 you would have a couple hundred head start on the slant 6! A compression boost 4bbl header and cam can really make a slant 6 run
                  • kursplat
                    1,039
                    266
                    Aug 24, 2010
                    so cal
                    Local Time:
                    4:51 AM
                    no pics? not even a hint what year it is? come on man... :(
                    • Agree Agree x 1
                    • DJC
                      DJC Well-Known Member
                      229
                      46
                      Sep 6, 2012
                      Chilliwack, BC, Canada
                      Local Time:
                      4:51 AM
                      Neck breaker, show car and low budget is a tough combination. Kinda like the old saying "good, cheap and fast - pick 2".
                      • Agree Agree x 1
                      • rumblefish360
                        33,434
                        5498
                        Jun 21, 2005
                        Local Time:
                        7:51 AM
                        Low budget performance build?
                        Need a rear end? Use the 8-1/4. Very under rated.
                        • Agree Agree x 3
                        • Like Like x 1
                        • dartfreak75
                          2,358
                          1130
                          Aug 10, 2011
                          Virginia
                          Local Time:
                          7:51 AM
                          The problem I found while looking for a 8.25 was one to fit an abody is extremely hard to find most of them where trucks and f body's and needed narrowing. Which ment new axles which ment more money! I had a 8.25 out of a truck i was gonna narrow and wound up selling it.
                          • Agree Agree x 1
                          • nm9stheham
                            9,930
                            2311
                            Dec 20, 2013
                            Waynesboro, VA
                            Local Time:
                            7:51 AM
                            From the intended use, the OP is surely needing to upgrade rear axles.. not question about that now. For the budget.. patience and part time jobs.
                          • james Farner
                            james Farner Member
                            9
                            7
                            May 27, 2017
                            San Dimas
                            Local Time:
                            4:51 AM
                            not really a show car, just something thats badass and not beat up.
                          • james Farner
                            james Farner Member
                            9
                            7
                            May 27, 2017
                            San Dimas
                            Local Time:
                            4:51 AM
                            06F3FCA5-33E0-41DD-A5A9-665D41CE6404.jpeg BA0487A2-B89A-4FF5-823F-EF61B7B107D7.jpeg 806FC1F4-49E2-457B-BDA2-2C8166A97002.jpeg 44FD29EB-1109-4AF5-95F0-C5912629C67B.jpeg
                            • Like Like x 3
                            • james Farner
                              james Farner Member
                              9
                              7
                              May 27, 2017
                              San Dimas
                              Local Time:
                              4:51 AM
