1970boy
Im buying an 8-3/4 a body rear end of craigs and wanted some opinions. Im not sure what these cost but im able to get one for a $100 is this a good deal for the condition of the rear end
Upside down in photo, so based on that & spring perch location (top) it is from a truck or van.
Trucks typically have lower gears than cars & vans could go either way.
Worth checking into, a clutch style sure grip is any easy 300 hundred bucks.
All true but prob. not going into a A body. If it does, not a bolt in project.What he said, it's out of a truck or van because the perches are on the top.
That said, for $100 it's already worth it. The brakes are worth that much, let alone the 3rd member. An A-body rear end that complete and in that condition would going for $500 or more.
Agree with all you said. But I guess it depends on what the OP is looking for. Not everyone has the capacity, or will to resale parts, To me I would have it already.No but for $100? You can probably have it shortened and the axles shortened and re-splined for $400 or close to it.
And regardless, find a 3rd member for $100. That's a freeway geared, open 3rd member price. If it's out of a truck or van it's probably 3.23 or 3.55, and if it spins freely even an open rear with those gears is worth that much or more. Even if you don't use the axles or housing you can make a profit on the 3rd member and brakes. Look at what a loaded set of 10x2.5" brakes goes for on eBay. It's over $100.
I'd have bought it already, no questions asked. Pick-n-Pull would charge over $160 for that thing, and that's a good deal. The 3rd member in my Duster right now is a 3.55 742 out of a D100 8 3/4 I bought complete at Pick-n-Pull. But I suppose I can weld and have a axle housing jig so it's a no brainer. It's a good thing it's not near Sacramento.
also which case is the more desirable? i know the 489 is pretty much the standard sought after but isnt there a more desirable third memeber?
The 489 has a stronger pinion gear, or it seems so. I have not actually checked any to failure.also which case is the more desirable? i know the 489 is pretty much the standard sought after but isnt there a more desirable third memeber?
i was just curious. its been awhile since i had to deal with the cases. wasnt the 742or the 489 out of the hemi/BB cars or am i thinking incorrectly? cant remember lolNot really. You can argue back and forth about whether or not the 742 or the 489 is the stronger case but really you're splitting hairs to say one is better than the other. I like the 742's because they don't have a crush sleeve, you can install a crush sleeve eliminator in the 489's though. But you'd have to install one. And I haven't had a 3rd member rebuilt yet, everything I've run was original in the car when I bought it or swapped in straight from the wrecking yard or swap meet.
So between the 742 and the 489 I would say it's really just preference. The 741 isn't as strong, but if you're talking about a street car you probably won't even hurt one of those unless you're running big horsepower or drag radials.
the clutch type are more desired correct?
i know thats what i put back in my 8 3/4 reccomended by the good ole folks here on FABO
Good to know. I mean it.
Got any pics of your work?
I don't need anything but just curious
