caliper help
hamsterhats
I just received the new calipers, they came without the "bracket"(not sure if correct terminology!) I tried ordering them today, they said that they do not carry them. If you can tell by the photos, will these be ok to use? They have tiny divots where they slide. How tight should the bolts on the bracket be? Are they to be loose enough so they slide?
Thanks
Just wire brush the braket and put a small amount of grease onit . They will work fine.
thanks. Should i replace wheel cylinder in the rear drums while i am at it?
If you are gonna do the brakes, do them all. This way you have some peace of mind knowing that you went thru the brakes and checked everything over.
