DART66GT
62 Lancer GT - B Body 8 3/4
Just bumping this upDoes anyone recognize this as vent tube for 62 Lancer?
Doesn't look like mine, but I know littleJust bumping this up
I did! You have to cut a couple of small metal tabs of, one on each side. I didn't take a picture of that but I do still have the tabs. Then you have to drill a few small holes for the upper grill mounts. The side headlight bezels go on with no changes. You have to drill the underside of the hood for that part of the trim.Anyone here put a 61 grill in a 62 Lancer?
Looks great! Do you have a photo garage of your car?I did! You have to cut a couple of small metal tabs of, one on each side. I didn't take a picture of that but I do still have the tabs. Then you have to drill a few small holes for the upper grill mounts. The side headlight bezels go on with no changes. You have to drill the underside of the hood for that part of the trim. View attachment 1715296885 View attachment 1715296886 View attachment 1715296887 View attachment 1715296888
It's almost easy.
It's a manual, joint isn't bad yet, just boot is torn. Would like to just clean, re pack and re boot.This:View attachment 1715300420 View attachment 1715300421
So you get a new shaft with the flange shown to take the place of the ball and trunnion u-joint. This is the easiest but costs the most. You might can find a vendor to sell you a new joint, but it won't be cheap. Is your Valiant an automatic or stick? If it's a stick maybe a swap to a later slip joint transmission, if automatic and you want to keep the buttons, you don't have much choice.
I'll make something work, probably a prop shaft bellows kit for boatsThey used to make a split boot that you could try. I never had any luck with them and they might be impossible to find. Good luck!
Any 62 experts! I'm almost ready to start this thing just the gas lines.Does anyone possibly have a pic of the gas line from a 62? I'm specifically looking for the routing from the front spring shackle to the tank . Is it a one piece line? How long is the flex piece of hose? Any info would help, any kind of pic showing any part of the end of the line at the rear would be great, thanks
I got my 62 Lancer jacked up for pics. I had the tank out last year and cleaned the pickup and put it all back with new rubber line. The pickup up as you see is right on that right side of tank right up besides the frame, and a rubber line goes to it from the steel long line. I will get pics of it all best I can.. NOW got to get the wife to download them!!!!!!! just a minute!!!!Any 62 experts! I'm almost ready to start this thing just the gas lines.
II got my 62 Lancer jacked up for pics. I had the tank out last year and cleaned the pickup and put it all back with new rubber line. The pickup up as you see is right on that right side of tank right up besides the frame, and a rubber line goes to it from the steel long line. I will get pics of it all best I can.. NOW got to get the wife to download them!!!!!!! just a minute!!!!
