flight704
I have a 96 ram 2500 4x4 with a 46re transmission. I bought it used about 3 yrs ago it currently has 108,000 miles on it to my knowledge it hasnt been touched yet.
The truck runs fine the tranny shifts fine and it does not slip or anything else.... all the fluids are good anyways when i am coasting down to a stop and the truck is in gear i hear a whining noise. If i pop it into neutral it stops and as soon as i put it back in gear it starts again. it doesnt matter if 2wd 4wd or 4wd low same thing happens i was thinking transfer case but it still stops when you pop in into neutral when in 4wd so i am convinced it is tranny related
anyways anyhelp ideas or guidance will be appreciated thank you for your time
duke
duke
