Calling those who understand Magnum 318/360 better than they do their wife...
TylerW
Elkton, TN
Hey guys:
In my never-ending quest to make as many questionable vehicle purchases as I can before age 60, I bought a "cheap" 2002 Ram 1500 single cab 4wd with a 360 Magnum. It's a solid southern truck which would be a nice rig if it was usable. I wanted one of these 3rd gen trucks ever since they came out but had to wait 20 years before |I could afford one.
Anyway, this truck is an oddball, since it's a 5.9L/46RE in a 3rd gen instead of a 4.7 or a Hemi w/ 545RE. It was sold as "runs good, no reverse". No reverse doesn't scare me since this is essentially a 727 with an overdrive stuck onto it. The broken parts are in the 727 side of it, at least most of them. Things went downhill when I started digging into the trans and discovered that "someone" had swapped in another 46RE out of a '99 something or the other. The issue here is that the 2002-03 Ram and possibly the Ram Van used a different version of the 46RE that utilizes a 5-pin range sensor at the trans to operate the electronic PRND2L display, and ostensibly tell the PCM what position the trans is in, and to operate the reverse lights. The governor pressure sensor is also different. I think the goal with that was to make the trans more responsive to road conditions.
The same someone had inexplicably connected the "new" trans' 3-pin nss/backup light switch to 3 random wires out of the 5 and cut the other two. I disconnected the entire thing since it doesn't interface. Disconnecting the wires didn't change what I am about to describe. Here is where things get really strange. I don't understand it yet, but I'm pretty confident that this is related to the PCM not seeing the right transmission.
1. Truck starts and run good in Park. If you drop it in reverse, even though there is no longer an actual reverse, and step on the gas, the engine cuts out, cuts up, loads up, pops out the exhaust and most of the time dies. This is not revving it to 5500 to get it to move and hitting the rev limiter. I mean as soon as you put pressure on the accelerator. Every time. I've seen other owners describe this mystery "runs like crap in reverse" issue with Magnums, with no resolution.
Out of curiosity, I completely disconnected the transmission electrically and tried it again. Same thing. The only difference was that the trans defaulted to 2nd since there was no longer an electrical input. So, I'm certain this truck is smarter than I, so where is it seeing reverse if the trans is disconnected electrically? Is it because even with the trans connected, the incorrect electronics are screwing with the PCM? It actually works decent in the forward gears, but there is no lockup and no OD. The shifts are slightly late but smooth.
2. This thing will start dropping out in drive at idle when it gets hot. If you hold your foot on the gas pedal slightly to keep it running and moving, it does this lumpff lumpff lumpff thing, then will die immediately when you let off. Starts right back up. Sometimes it doesn't do that at all. Up to about 170 degrees it exhibits no idle issues in drive.
There are no codes serious enough to trigger the money light. It does set a P01899 for the missing range sensor.
Anyway, just wanted to pick people's brains about a really strange symptom. I'll track down the correct trans for it and build it. Thanks for reading.
Can't help with the diagnosis, but gotta say that's a cool optioned truck with the 5.9L Magnum. Can't be too many of those left. Good score and good luck.
I'm thinking the 1st thing to find out is how the PCM functions, I have a 97 ram 1500 5.9 with 45re trans. I would download FSM I've read PCM section a long time ago, so can't recall much, but remember they explain it very well. If you have trouble getting downloaded FSM, DM me for a copy. Just run search for 2002 Dodge Ram Factory Service Manual
Nor trying to argue but I thought the 46RE (electronic) had 9 pins and the 46RH (Hydraulic) had 3.
I know the OD on the Rh has to be done with some fenagling (adding a switch) when retrofitting into non computer controlled vehicles which sounds like what they did. Other than that I'm of zero help. lol.
Yea there is some confusion over the terminology being used.
46re
46rh
Both are 518s which are a derivative of a 727 with overdrive and controlled differently. RH is hydraulically controlled and RE is electronically controlled. To further confuse things there were two styles of electronics used on the 46re. And it had to do with the range selector sensor and park/neutral saftey. As well as output shaft speed sensor (I think, I’m going off of memory here)
Looks like 2002 was when the update was done to the 46re with regards to the range selection sensor. And they are NOT compatible.
