Caltrac Suspension
ahlberg
Active Member
Hi can anyone give me some info on caltrac suspension? Are they good for street/strip?
Yes. Wait, YES! Very good. Do a search. I have read good things about them.
Yes they are excellent for both!
If you need new springs go with the single leaf spring that is designed to use with the Caltracs, otherwise they work just fine on the Street- never now they are there.
It depends on your springs. Read the paper behind the link Adam provided.
I think that is why there is multiple bolt holes in there, so you can get as close to your needed dimension as possible. Probably not optimum, unless you are lucky.
