Dragonbat13
Ok, im getting parts for a budget rering smogger 360 with stock heads. Of course compression is low. I do have headers, hi rise dual plane, comp xe262 cam. I am strongly considering Rhodes superlube original lifters. I need to get a timing chain. What I want to know is, if I should look into chains that will allow me to advance the cam?
On a side note, if you had a 650 afb and a 750 AVS which would you run? I'm leaning towards the 650.
