nm9stheham
BTW, the FSM's often have the WRONG torque number for the rocker shaft hold-down bolts. Take them ONLY up to about 20 ft-lbs.
Way too deep now to turn back.Get some calipers and measure the lobes, short and long side, subtract and multiply by 1.5. That should be a close guess at lift.
If the old cam is a 285, I'd bet it's similar to the old 230-480 camshaft. Most of the aftermarket had cams in the 230-235 range and 475-485 lift. A Comp 268 has the same basic lift with a little less duration at .050 which should settle down the idle a bit.
I think you should have done other things to make what you have work using a degree wheel/dial indicator and getting more initial timing on it. You are in too deep now to go back.
Comp says to break in the cam by fluctuating the rpm between 2300-2500 for 30 min. I'm going to use conventional oil. Either the comp cams break in oil or conventional with their additive.Separately is OK. Just get the right length bolts in the right holes.
Just make sure you can place a straight edge center-to-center on the crank and cams and have the dots aligned right on that edge. It is easy to get a tooth off. It looks good in the pix.... but looking at a pix is not the same as being there.
Makes sure you lube up all the cam lobes and lifter bottoms liberally with the supplied lube.
Have you read up on the proper break-in procedure? What oil are you using? That is important.
they are straight. However, now that I rotated the crank so #1 was firing, the cam dot is now at the top of the gear.Separately is OK. Just get the right length bolts in the right holes.
I thought decreeing was confirming/checking that it is what it says it is. I don't see any other method of setting it's position other than with the teeth on the timing gears. O settings are aligned right now.So you didn't degree the cam? Not a smart thing to do. Best to verify it's installed where it should be.
Yes, that is right.they are straight. However, now that I rotated the crank so #1 was firing, the cam dot is now at the top of the gear.
This is a way to at least say that the cam chain is on the right tooth. It eliminates the chance that the cam is 15 degrees or more off, but does not show that it is 3 degrees off.You probably dont have to degree it but to roughly verify line up the timing marks as best to straight as possible, put in both i&e lifters put a straight edge across the top of bot lifters.The intake lifter should be around .010 to .020 higher than the exh lifter when the valves are on overlap that should be 2-4 degrees advanced.
I was generally agreeing with you....and I understand what you are saying. I am not so sure of the number of thousandths per degree as you ...... lobe ramps can vary so much, as well as the difference in durations for intake vs. exhaust will change this too.Your wrong, on overlap usually if the lifters are equal height it has no advance if the exh is higher its retarded if int is higher its advanced.Its not exact but close,usually about .004 thou per degree of adv., so intake higher by .016 to .020 about 4 deg adv.Most dont degree but it gives you a good rough idea.
Yes. Did you put the oil slinger on the crank before the timing cover?Anyone know what goes between the crank end and the timing cover seal? Is that space taken up by the harmonic balancer?
Good to know. I used all the original bolts so I should be good. However, I will pull all the lower ones and place some thread seal on them. I didn't know hey went into the jacket.There is a hole in the front of the block, on the drivers side, where the timing cover bolts on. This hole goes into the water jacket. It is possible to put too long a bolt in there during the cover install, and it is possible to drive that bolt right through the cylinder wall. This will allow water into the oilpan and really spoil your day when you find out.
BE CAREFUL!
