6dart9
- Joined
- Jan 8, 2008
- Messages
- 762
- Reaction score
- 14
I know this topic is on here a lot but if anyone could give me their opinion that would help a ton
here is what I have
340 block ( I was going to stroke it to 416 but changed my mind) Bored .030 over
I have the O heads with the 2.02 valves
I was looking at this cam
http://store.summitracing.com/partdetail.asp?part=CCA-K20-225-4&autoview=sku
which is
Intake Duration at 050 inch Lift: 240 Exhaust Duration at 050 inch Lift: 246 Duration at 050 inch Lift: 240 int./246 exh. Advertised Intake Duration: 284 Advertised Exhaust Duration: 296 Advertised Duration: 284 int./296 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.507 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Will this be able to drive on the street or is it to big of a cam. Should I go with the 274 or the 268?
Thanks for the advice in advance
I did put it into the Comp cams program and it is under 6 - Auto - Series Street, Some Strip, Mild-Rough To Rough Idle
Justin
here is what I have
which is
Justin
