Tejas
Active Member
- Joined
- Jan 3, 2008
- Messages
- 44
- Reaction score
- 5
To start with: Sorry for the overly long post but I want to get this right the first time.
I’m looking for some advice from some of you that have a lot more big block Mopar engine building experience than I have.
I’m to the point of buying engine components for my low deck 470” build.
Next month I’m buying a pair of 440 Source Stealth heads, I’m going to have a friend go through them.
He’s going to do some mild porting / port matching, change the valve springs, set the installed height, spring pressures and check everything out.
In order to do that he needs the valve springs I’m gonna use. In order to do that I need to pick a cam.
I have always planned on using a roller hydraulic cam set up because I want it to be a rock solid long term reliable engine because it will be primarily a street car.
I called and spoke to Hughes Engines today and spoke to one of their tech guys and he gave me two recommendations, one a roller hydraulic and one a flat tappet hydraulic.
I gotta admit the flat tappet hydraulic set up is looking good to me just based on cost. The whole set up will be about $1000 cheaper this way.
The Hughes tech guy tried to assure me that everything would be OK as long as I used the recommended oil and break in procedures.
My original goal for the car was to get it to the mid 10’s, now I think it’s too heavy and it doesn’t have the right kind of rear suspension for that.
I’ll be happy with 11’s.
Please give me any recommendations or suggestions you have.
Here’s the car and combo.
1971 Plymouth Duster
Approximately 3400 pounds
Subframe connectors
Mini tubbed
· Mancini XHD rear leaf springs
· Reilly Motorsports rear leaf spring sliders
· 3.91 sure grip B body 8 ¾” rear axle narrowed 12”
· 15”x10” rear rims with 3.5” backspacing, 325/50/15 tires 28” tall 12.8” wide
400 low deck block
440 Source 470 stroker kit
3.915” stroke
4.375” (+.035”) bore
6.535” rod length
Flat top pistons, 10.77 compression ratio with 84cc combustion chambers
440 Source Stealth cylinder heads, mild port and polish
Hughes 1.5 ratio roller rockers and shafts
Offenhauser tunnel ram intake manifold
Two Holley 600 cfm vacuum secondary carburetors
Pro Parts 2” primary and 3.5” collector semi fenderwell headers
727 built to high performance specs
Turbo Action 17805ST torque converter 3400 stall
Here are the two cam recommendations.
HUG HEH5055BL3
HYDRAULIC CAMSHAFT 108º LSA+3
FLAT TAPPET HYDRAULIC / THREE BOLT TIMING GEAR
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5
.576"
.593"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6
.614"
.632"
Intake Duration at .050"
Exhaust Duration at .050"
250°
255°
Lobe Separation Angle
108º
Intake Opening at .050"
Exhaust Opening at .050"
20° BTC
58.5° BBC
Intake Closing at .050"
Exhaust Closing at .050"
50° ABC
16.5° ATC
Min. Suggested Cylinder PSI
200
Sweet Spot RPM
2800 - 6000
AND
HUG HER4652BL
HYD ROLLER CAMSHAFT 110º LSA +3
HYDRAULIC ROLLER / THREE BOLT TIMING GEAR
Hydraulic Roller / Three Bolt Timing Gear
.555"
.540"
.592"
.576"
246°
252°
110º
16° BTC
59° BBC
50° ABC
13° ATC
Sweet Spot RPM
2000 - 7000
Subframe connectors
Mini tubbed
400 low deck block
3.915” stroke
6.535” rod length
HUG HEH5055BL3
.576"
.593"
.614"
.632"
250°
255°
108º
20° BTC
58.5° BBC
50° ABC
16.5° ATC
200
Sweet Spot RPM
2800 - 6000
AND
HUG HER4652BL
.555"
.540"
.592"
.576"
246°
252°
110º
16° BTC
59° BBC
50° ABC
13° ATC
Sweet Spot RPM
2000 - 7000
