cam choice review..
BTW Earlie any particular brand retainers to get? i assume 10* not 7...
If you are using 1.55 diameter stuff and solid roller I would go 10 deg. The little PAC springs use what they call a mini 8 degree.
You also asked about a brand - didn't catch that. Look at the spring specs and they should recommend a retainer. I would stay with the same brand as the spring and use the recommended one. That way you know all the diameters and offsets will work with the spring.
k.. thanks.. yeah not sure what the springs will be, he puts his own part # on them but i'm sure they are pac or someone else...
haha just sitting here thinking.. i could have built a 440 and put a 8-71 on it for less than the stupid **** i'm doing :) but this is more interesting to me
FYI I think most here know my tastes and this is what I put in the A100. To be honest I did NOT like it. Too much cam, too lumpy, made less seat of the pants power down low than my 318 with the cam that is more like what you said you have in your 318. I would never put that large of a cam in anything that I want as a nice street cruiser. Yes I could have put a higher stall converter in it (put in a 2800) but I would have hated that even more for the street.
Chrysler Small Block Compatible 408 c.i. Engine - 375 Horsepower - Long Block
It's so easy to over build. It's also easy to be over-impressed with the maximum torque and horsepower numbers on a chart or dyno sheet and forget about what it produces from idle to say 4000 rpm which is where you will be spending most of your time on the street.
Do you think you're gonna miss out on 50HP from one similar cam to another? Stop making yourself insane and just pick one and go. Everybody's recommending similar grinds, so there's your answer.
Every thousandth of lift and duration matters damnit!
Bout time. lol
It's a lot of money to me... i have to work myself up to it... i emailed him and asked him to respec the cam to 6000 and i'll take the cam lifters and springs... i will never go over that driving around town so silly to setup for that high
Hell, you're preachin to the choir about money. If that's you're biggest hangup (and mine too) we're in the wrong hobby. lol
So for 'just a street car for fun" you need a solid roller 255/259@ .050" / .619"/.618" Net Valve Lift cam? I learn something new every day. :)
ps I hope its a great cam for your engine
But it's also like it's gonna see 6000 and say "ok I'm stoppin right here!" How bullcrappin stupid does that sound? Of course it'll go higher.
Max cubic inches = Max cubic dollars. Glad you have deep pockets. I would have built a 6-71 360, good heads with a SFT cam and called it done. But I'm a frugal SOB!
haha my pockets aren't deep.. i'm just stupid :) And i want a blower SOOO bad it hurts.. maybe in a few years... I paid my house off. .and have zero debt.. so this won't kill me.. still doesn't make it easy to hit the button though..
well.... if you are going to have fun.. have fun :) at the end of the day it doesn't matter.. i will do 50mph to work every day and never actually beat on it..
I was thinking back to what Hughes recommended for my 408 Eddy headed 10.5:1 build. The cam was about 4 sizes smaller (hydraulic roller) @230 degrees and about 0.510 lift.
The cam in my 318 right now is bigger than that, runs pretty good..
BTW... i am having him spec a slightly small cam... i was a little over the top on the first one.
Car/Cam
BTW.. i know how dumb i am and overkill it can be... i'm just having fun with it.. at some point i will get bored and sell the car for like 1/10th of what i have in it.. happens every time
Nope. We won't let you. Just don't over build your stroker to the point that it's not fun to drive, and I'm not talking about the fun you have jabbing the gas and the *** end want's to catch up with the front end. Well may be I am talking about that. We build strokers for low end torque but we seem (some of us anyway) to be building a stroker for maximum horsepower at 6500+ rpm. I laugh at those builds on a dyno, the operator starts testing at 4000 rpm or so. Hell, that's already out of my normal driving RPM range. :poke: :rofl:
