Swapping my 87 Dakota from 3.9la to 5.2 magnum. Found the cam has a chewed up lobe. What the best replacement cam for stock engine.
are you keeping it EFI or going carb?Sorry I guess I should have been more specific. I was hoping to find a cam that is a bit “warmer” as you say without too many more upgrades.
A stock Magnum cam.
Then the sky's the limit. Just remember, whatever camshaft you choose requires a matching set of valve springs.Carbureted.
I like these specs. No torque converter change needed. Increased torque and HP to 5500, no problem.Oregon Cam Grind # 1341 is a nice one. 218/224@.050", .482" Lift with 1.6rr, 110°LSA. Good Power / Torque.
Michael
I think that's the one I recommended for @TrailBeast. Maybe he'll chime in. I think he likes it pretty good.Oregon Cam Grind # 1341 is a nice one. 218/224@.050", .482" Lift with 1.6rr, 110°LSA. Good Power / Torque.
Michael
I couldn't remember exactly. I know yours is the same one I used in the Ford 5.0 that I built a few years back. I ended up selling it to a friend's son and he put it in a little square body short bed Ranger. It has balls.Mine is super close to that.
214/224
Good torque and great mpg.
Agree 100%(or moving the torque up is probably a better way to say it),
Starts to effect under 2000 ish rpms ?is a 212/218 @050. Anything larger than that starts to move the curve up.
Lets make this post helpfull...A stock Magnum cam.
Started to effect it as low as the dyno could reasonably start the pull. ~2500Agree 100%
I ConcurLooking at the graph right at the start it would appear that they cross over. But that is more a function of the dyno grabbing the engine. These two are essentially identical at ~2500 ish
