cam identication needed
flathead5173
Active Member
wadsworth ohio
I have a cam that is stamped on the end MP with numbers. I can't make out the first number. I believe it is either the letter S or the number 8 or 5 or 3. I have a picture. I've measured the lobes and the intakes are around .300" and the exhaust around .310".
From the lift figures, that's most likely the MP 4452761. Good street cam. One step above the 340 cam.
Is it purple? If its a Mopar cam. This numbers may just be a contract number. You must measure the lift. The .300 is about a .450 lift in a perfect world. The .310 is a .465
