cam identification help?
javelin390
Member
puerto rico
]how identify my purple cam small block 340. the cam have in the end 3 number
111028
260315
252501
what is the lift and duration and the part number in the mopar catalog
thank you
those numbers won't help with cam ID. part number should start with 4. If you can't find part number measure with a caliper across round part of cam lobe, then measure across cam lobe itself. Subtract the first measurement from the second then multiply by 1.5, this will get you your valve lift. Might be able to figure out what it is with those measurements.
I think Purple shafts just had manufacture numbers on them, not part numbers. Best way is measure lift as that narrows them down fast. Some hydros are only .001 from a mech though.
111028
260315
252501
thank you[/QUOTE]
[ame]http://www.mopar.com/assets/pdf/catalog/mopar_performance_parts_catalog.pdf[/ame]
111028
260315
252501
thank you]
