Stroke. yes Displacement. noPost #22.
Displacement has plenty to do with duration. Greater vacuum [ or suction ] is created by larger displacement which pulls more weight of air into the cyl.
As already prescribed, the 270S is a great choice by the OP. This cam was originally marketed as a 'variable' duration cam; the seat duration can be varied 10* because the range of valve lash is 0.015-0.030". So some built-in tuning flexibility.
A longer stroke handles more cam duration.
A big bore short stroke will be less efficient with a long duration cam.
