I am in the process of rebuilding my slant and want to "up-grade" the cam for a bit more wallop. What would you suggest for a cam to go with:
Slant six (225 cu.in.) 1970 block bored 30 over and the crank turned 10/10 under. Will have a 390cfm four barrel (as soon as I can source one at a reasonable price...{any assistance here would be appreciated}) as I have the intake. Exhaust manifolds have been split and welded so as to be able to run dual exhaust (two collectors). New timing gears,chain, oil pump, pistons and rings, new bearings. Head was done with new exhaust valves and checked by the engine rebuilding business; shown as good including being trued up.
Again, it is the cam and lifer combo I need help choosing. This will not be a race car but rather a general cruiser. At 55, this is also probably the speed I will be driving it on the highway. It also will have the stock rear end for a slant six car.
Thanks in advance for any and all information you may wish to input here.
Cheers Paul
Cheers Paul
