Cam selection
juvat
Hey guys, I am looking to switch over to a solid roller cam cause I want some more power. My flat hydraulic lifters always feel like they are collapsing when I try and preload them when adjusting the rockers. As a result I always adjust them where I just barely start feeling the pushroad getting resistance, causing lots of valvetrain clatter. I think I should just say the heck with it and convert over to solid since I'm adjusting them all the time anyways and I can take the variable of preload out of the equation. However, I don't know what type of duration I should get for my set up. Therefore I am solicting opinions, looking to keep it streetable (weekend cruiser not a daily driver) and still be able to pull to 6000-6500rpm for occasional use at the drag strip. I think a solid roller would be a wise investment, but when I look at their specs they have higher durations than I’m used to seeing, and look like they might not be very streetable. Here’s my combo:
72 Demon
10.25:1 LA 360
750 double pumper
Eddy rpm air gap manifold (I also have a torker II that I just replaced because it was a dog with previous set up below 2500rpm)
Eddy heads
Comp Magnum 280H cam (230/230 dur at .050, .484/.484 lift)
273 adjustable rocker arms
FBO ignition
Small tube headers
4 speed
3.91 rear
26.5” tires
Thanks much!
Al
274 XE SOLID CAM #CL20-230-4
SOLID: Great for street machines and mild bracket racing 9.5:1 compression with 2800 stall, lopey idle.
.016 lash
.018 lash
2200-6200 rpm
20-230-4
XS274S
274
280
236 duration at .050
242 duration at .050
.502
.511
110°
CamQuest likes the XR274R (236/242@0.050;0.564/0.570) 552HP@6000, 524 ft-lbs@5000.
Or the XR280R (242/248@0.050;0.570/0.576) 554HP@6500, 520 ft-lbs@5000.
You know about OU812's retrofit roller lifters? No block machining required, they say.
CamQuest shows your current setup as 484HP/468 ft-lbs.
