Correct me if I'm wrong, but -15 btc @ .050" does mean the damn pointer on a degree wheel should be to the right side of the TDC mark at .050" lift?
Installed centerline's 111, had to advance the cam a full 8* to get there. Helped the .050" opening number, at least it's at 12* atc instead of 20*. Watching the indicator, the closing point is way screwed too, something to the tune of 78* abdc before the indicator stops moving. Degree wheel's set within a half degree, triple checked it.
Cam specs from the card:
Hughes roller, 9204AL
LSA 114
Installed CL 111
lift .459/.471
duration 192/204
timing @ .050"
intake opens -15* btc
closes 27* abc
exhaust opens 39* bbc
closes 15* atc
So what the hell am I missing here?
LSA 114
Installed CL 111
lift .459/.471
duration 192/204
timing @ .050"
closes 27* abc
closes 15* atc
