I only know that Cams advertised duration and IIRC, it’s 288/292. What it is @050, I’m not sure of. *I think* I read it was 230@050 intake. 236 exhaust.
Can anybody verify that?
Moparcody, a more aggressive valve lifting cam at the same duration @050 would add power in addition to more useable lift if the head can handle it.
Is this a street car?
It was asked above (?) to post gear ratio & tire size and car weight. I don’t know if you can get all the other stuff listed above. The gear and converter may allow for more cam duration. I would not want to add much at all if any.
