SRT_DSTRHOLC
I have a new cam installed and I want to install my timming set, but theres not key on the new camshaft, what do I do? Can i use the woodruff keys from dorman? or what is needed, thanks
If it is a little low in the front it will level under the cam spocket.I found a key that fit in and needed to be taped in, is there a way to make sure its all the way in with out it tilting?
