ok stroker 360 , rhs heads, bout 11.4 comp ratio, bigtor jr. holley hp 950 1 7/8 hedman w2 headersThere's no basis of "what to think" without an application and all other associated combo items. It's like goin to a whorehouse and pickin a gal without lookin at um. Need LOTS more info.
its a hydraulic roller.I don't care for the big split, but other than that, I like it.
What does the cam card call out for lash?
Also, if you have 1.6 rockers I'd use those. I like lift.
Save your money and aggravation and find a solid roller grind.its a hydraulic roller.
i'll never be able to look at a cam lobe in innocence againThere's no basis of "what to think" without an application and all other associated combo items. It's like goin to a whorehouse and pickin a gal without lookin at um. Need LOTS more info.
It’s build dependent I think. Extra exhaust helps. You do t need a dual pattern cam. If it should (key word) help.Oh how quickly the tide changes, just a couple years ago if you mentioned a single pattern camshaft everybody said they were obsolete, a lot of it was propaganda to help sell new cams
Well...that crap canned my idea.
Still, I like the grind. Just not a big fan of that much duration split.
Yes I totally understand how in some or most stock applications it can help, but all of the modern heads Edelbrock trick flow ProCom whatever exhaust Port will outrun the intakes. So in my opinion I just find it strange that the so-called new modern cams are still catering to a restrictive exhaust side. And I'm also not saying that all cam Grinders buy into that, just an observationIt’s build dependent I think. Extra exhaust helps. You do t need a dual pattern cam. If it should (key word) help.
What do you guys think of this profile for a small block Mopar and why??
intake 307(adv dur) 254 (.050) .171 (.200) .365(lobe lift) .548 (1.5)
exhaust 317 264 .179 .341 .512
I wouldn't know but I've been told that is what bags are for ..... LOLThere's no basis of "what to think" without an application and all other associated combo items. It's like goin to a whorehouse and pickin a gal without lookin at um. Need LOTS more info.
