http://www.passonperformance.com/
Article in a mag; http://www.carcraft.com/techarticles/116_0705_overdrive_transmission/photo_01.html
It goes from a regular to a OD, but info could be good for the reverse.
i have spoken with jamie at passon about this and what outsider has said is true,there is a pdf file at passon website that explains it but here is a chunk of it..... Pa s s o n P e r f o r m a n c e . c o mThe Passon OD was designed by Passon to utilize a standard 4-speed mainshaft. All the OD transmissions I have cannabalized have a mainshaft with the 3rd gear landing being smaller than a standard 4-speed mainshaft. I have not been able to use an OD mainshaft for a 4-speed yet. Unfortunately.
Not the input shaft.So basicly what we're looking at being able to re-use would be the case, tail shaft housing and the input shaft. Correct?
Ted
