Can anyone tell me what this is?
Bmsjax
Layton, UT
This is off a 360 block i bought. Its got a date stamped on it 2/8/72. I dont see a Chrysler stamp on it anywhere so I dont know if its stock or not. It doesnt have any moving parts so I'm guessing a pump of some sort is mounted on it as well? Does anyone know anything about this?
This is for a marine engine. I can't remember but the center of the housing drives something off the camshaft. Just can't remember what! If you have the original engine that this came with, the cam and distributor drive is different as well. The engine ran the opposite direction!...
You have a marine motor with a gear drive reverse rotation cam shaft,most of this motor is junk,might be able to save the heads,only the block and crank and rods will be any good,the rest toss,mrmopartech
Yes, always throw away anything that can't be bolted into your car. No one with a boat could ever use any of those parts.
I guess you were trying to be funny?
Marine motor huh? Interesting as I was told it was outta a truck. Just proves you cant trust everything your told. I was gonna swap the dist with the one in my 318 cause its the electronic version but i'm glad to hear it wont work before I spent hours trying to figure out what wasnt working right hahaha. So cam, dist, water pump, timing cover and pistons are no good to me? Well I was replacing most all of them anyways so no harm no loss. Anything else marine specific? I wont go as far as to just through them out though. Where would I find someone in need of these parts?
Don't get too darn excited just yet. Nobody HERE has seen this engine, and nobody HERE knows that it is a reverse rotation engine. Just because it "may be" a marine engine does NOT MAKE IT reverse rotation
True GOOD point. What would show the direction it rotates? Would cam teeth be different? I dont have the cam out yet but the rest is torn down.
If the cap and wires are still on it,you could tell by the firing order of the way the plug wires are in the cap.
Dist. tag is No. 3656672 Chrysler prestalite. But lookin at it wouldnt the dist work with either a marine or auto motor so long as the cam rotates right?
I would think so. The oil pump drive with the gear on it would be different.
2 motors side by side, one goes 1 and the other goes the other. Something to do with the boat torquing when you blip both motors if they were in synch.
OK, a marine engine probably has the cam gear driven. If you have mechanical fuel pump mount, pull that open, look in there and see if it's chain or gear.
Probably the best way is to run no1 cylinder manually through a firing stroke. Pull the valve cover, get a socket on the front bolt, and bring the timing marks up with both valves closed. Now just slowly rotate the engine, and visually watch the no1 valves. A normal engine rotation, starting with TDC, which is "combustion, will go down 1/2 crank turn (180*) and at some point the EXHAUST valve will open, then another 1/2 turn will bring piston back up WITH THE MARKS AGAIN at TDC except now both valves (near TDC) will be slightly OPEN (split overlap) At this point the exhaust will be CLOSING and the intake valve will be just starting and OPENING. One more half turn (180) from the TDC marks the exhaust will be finished closed, the intake will open and close, and finally, another 1/2 turn coming back up to TDC both valves will again be closed and back at your starting point.
A REVERSE ROTATION ENGINE WILL NOT follow this sequence.
You may not be able to tell by the distributor, because if the cam is gear driven on a reversed engine, the oil pump and distributor will be driven the same direction as a vehicular engine.
THE DISTRIBUTOR YOU PICTURED is for CW rotation of the distributor. Here's how you tell on ANY distributor:
"Spring" the rotor and see which way it moves. If you have to move it CW AGAINST THE SPRING, and it "springs back" CCW, then it is for CW CLOCKWISE rotation.
Look at your vacuum advance. When that advance lever moves, it pulls the pickup coil CCW WHICH IS THE SAME RELATIVE MOTION as moving the rotor CW
THAT DISTRIBUTOR is for CLOCKWISE rotation.
THAT DOES NOT MEAN that it came out of a "normal" rotation engine.
And I found some dope here:
Evidently the LH rotation engines use "normal" distributors and oil pumps BUT THE DRIVER GEAR causes a thrust problem on the dist/ driver gear/ oil pump so the LH rotation engines should have a special wierd not to mention different piece where the distributor sits to provide a thrust bearing, and what I've read indicates it spaces the distributor up somewhat
http://www.marineengine.com/boat-fo...tor-Gear&highlight=chrysler,+reverse+rotation
http://www.marineengine.com/boat-forum/search.php?searchid=171906&pp=
In the pic is a marine water pump housing for a double impeller pump, the pump mounts to the "C" shaped part hanging off to the side. The hole in the middle w/the plug in it is for the tach drive. I dont think that tag is for that distributor, Prestolites were cast iron and I've never seen a marine engine with a vacuum advance distributor.
