It's the original distributor for a '73 225
But there's been some changes to the engine.
@timk225
You can but is there any reason to think the vac advance is not working?
A vac gage and or Mightyvac is well worth cost if you don't have yet.
Did you ever measure the timing vs rpm?
For highway mpg, have you tried leaner main jets?
In my experience with a '75 fully smogged 4 door, 16 mpg in mixed driving is typical. With a '68 Barrcauda notchback, the 225 got over 20 mpg on the highway. Not enough local driving with it to have reliable mixed driving mpg.
The distributor tag number is 3755042. There's also a 50 and a 2 on the tag. Vacuum advance was ok. I've since changed the carburetor to a 350 Holley 2 bbl, it'll idle slowly now. I have a tach in the car. I'll have to check the timing and see what the numbers I get are.
No I didn't use a piston stop to verify the timing mark is accurate.
