Have a few they were adjustable also on the mechanical side with easy keys Rob
The engine actually seemed to like idling at 25* BTDC.......I dropped that back to 20* to get the T-slots and air mixture screws somewhat in check.I like the MP as timing is all in at 3000 rpm. Isn't 20 degrees a lot of initial timing?
I’m not well versed in Mopar advance curves (last distributor i dealt with you could design your own advance curve on a laptop and upload to the distributor) but i think it comes in too quick. Perhap I will drive it some more before I consider changing anything. I assume i will need to swap the light spring for something a bit heavier?Thanks, by the look of the springs I figured full advance would be in by about 2000 RPM. I will be putting a timing light on mine this weekend and report back on the factory settings. I will likely weld up the slots over the winter myself. I am aiming for about 20 initial and 35 total as well.
I wonder if you had welded the other side of the slot how it would have come out. Little more preload on the springs.I’m not well versed in Mopar advance curves (last distributor i dealt with you could design your own advance curve on a laptop and upload to the distributor) but i think it comes in too quick. Perhap I will drive it some more before I consider changing anything. I assume i will need to swap the light spring for something a bit heavier?
I wondered about that. I'm no expert on how the advance works but I think the advance would start a bit later but by how much? Or do you end up having to turn the distributor as its advanced too much at idle? The curve would otherwise be the same I think. The other issue is that max advance would come in quite late because the slot is way out there. If I do fiddle with it I have a few springs off of my parts distributors to try. I will have to try and measure the springs, spring tension and see if there is something a little heavier. Perhaps Halifaxhops can help if that time comes.I wonder if you had welded the other side of the slot how it would have come out. Little more preload on the springs.
I believe that. Just look at the OEM curve above. Its my (perhaps educated) opinion that if your going to weld the outside of the slot and run a lot of initial advance (20 degrees) the mechanical advance will need to be slowed down some. I said I wasn't going to mess around with the distributor after welding the slots until I ran it but I had to pull the distributor to drop the tranny so I did. From what I can tell the little spring allows for rapid initial advance to about 10 degrees (per the OEM curve above) and the big spring doesn't do anything until well after 15 degrees advance which the distributor will never see with a 15 degree (crank) slot. This means the distributor is only running on the light spring. What I am going to try is replacing the heavy spring with another light spring out of my old 340 distributor. It will slow things down but by how much?I did some timing checks today. When I set the advance to 35 degrees at 2500 rpm, I ended up with 25 degrees at 1000 rpm. The problem is when I increased the rpm it slowly kept advancing and ended up at almost 42 degrees at over 3500 rpm. My conclusions are that the light spring is giving me extra advance at idle and the stiffer spring is not giving me full advance until over 3500 rpm. This seems to agree with what other people have noted as sticking slots.
I mapped out the advance curve more carefully today.
1000. 15
1500. 18
2000. 22
2500. 26
3000. 29
3500. 33
4000. 37
I connected the vacuum advance and it was pulling 22 degrees for 48 total at 2500. I need to change the springs to get the centrifugal in quicker, and limit the vacuum advance over the winter.
Its got a little slower curve than in my MP distributor.I mapped out the advance curve more carefully today.
1000. 15
1500. 18
2000. 22
2500. 26
3000. 29
3500. 33
4000. 37
