CAN SOMEONE ID THIS TRANSMISSION?
easyrider
65 droptop
Crystal Springs, MS
It's a 4 speed I know and also Mopar. That's all I know.
What does the input shaft look like? They also used the aluminum 4 speed overdrive in gm trucks but it had a different input and I believe output spline.
Input is same as 23 spline 833. Big front bearing, too. I think.
I think you are correct in that the ones used in the gm stuff was a gm input. The chrysler stuff was chrysler input. I think anyway, I could be mistaken.
GM ones also had the obvious GM bolt pattern "pretty much"
On second look maybe the shaft for reverse is just so grease coated hard to pick up.
I'm going to suggest an OD unit from a "miser truck", being that it has the long tail shaft with the "B" and "E" shifter pad location and an aluminum case. somewhat like this.
It's an A833 OD out of a 1/2 ton or D50 truck, '75-'87. Tailshaft with the B/E shifter locations and the rear location not drilled and tapped is the giveaway.
More info on the OD transmissions here 4 Speed Transmissions transmission
