Okay I'm gonna give this a shot. I have read through all I can on aligning a front end. It all makes sense. I get everything right, make a trip around a lil asphalt test area at an old school next door. Half way through the road test, I drive straight and stop, get out check the front end. Things feel great on the road. Things look great front out in front of the car. Drive down the hill to leave the school, make a curve and can't hold it in the road at 10mph. Have major positive camber (top of tire leaned way out). And toed in. I cannot find a bad tie rod, ball joint and i replaced the only bad lower control arm bushing. The a arm bushings seen to be in good shape also. I have checked the tabs the the cams push on. They seem fine.
I have adjusted everything multiple times and always the same thing.
