Hey Guys,
I have a 418 that was recently put together/fired up and began mixing water and oil. I pulled it back down and on closer inspection I believe I have found the issue. My question is what are your thoughts on fixing this? Can it be sleeved?
If this can't be saved/sleeved etc, what are my options? This is a 340 block, so I can not just put this stroker kit in a 360 block can I? As I understand it the mains are different even if I had the 360 punched out to .080 over, my 340 is .040 over.
Thanks
Thanks
