340 piston I'd question
2b406070
With out getting too accurate
About .005 pop out
I'm trying to stay close to stop compression ratio
Then make sure you put the largest open chamber iron heads you have on it. jk but yes those are direct replacements of the strongest kind, just as heavy as as stock.. but they wind up just fine. May be noisy when cold though, but dont sweat it. They just require more skirt clearance is all to grow/expand, like near .008.
I've sold 2 sets over the last 4 yrs.
You never know exactly what the weight of those pistons are
I have a set for a 440,,,,they are forged as well TRW s
They weight exactly 1 gram less than a factory stock 440 piston from 1968
So
You never know what you have until you check the weight
So
Good to be a hair lighter out of balance 'on the rod/piston end' than heavier.
Thanks is that good ....
They look spiffy...
Think im using the O heads
Its going to be a driver so don't
Want over stock 69 340 compression
I'm running the old school TRW forged pistons in my 65 Barracuda 340, with Edelbrock heads for a 340 that have combustion chambers machined (I think) .030 for clearance with pistons having a mild positive deck height.
I've not attempted to accurately assess my CR, although I'm thinking it's under 10:1 despite the pistons being called 10.5:1 and having heads with combustion chambers smaller than stock (65 vs. - what - 72 or so?). Cranking compression is 165.
If I opened up an engine and saw that I'd be cacklin' an' crowin like an old rooster!!!
so looks cast to me
i do like the oil pick-up has a ok pan ...that i wont use
don't like the bolts holding the windage tray on
There was a roundy-round car went thru 2 seasons and numerous engines losing oil pressure at hi-rpm, traced it to a pick-up similar to that one.
Sucked the bottom of the pan onto pick-up screen.
I suggest some kind of spacer, nut, washer welded to bottom of the screen to ensure maintaining a gap.
jmo
so looks cast to me
It appears cast......but if it is, it's nodular iron. Very strong for cast iron. See how smooth that counterweight is and the grain? If you get a picture of the parting line on one of the crank throws, we can tell for sure. Pencil lead thin line and it's cast. About a 1/2" wide line and it's forged.
That’s possible .
But the bolts for the tray are normal strength hardware .
They might even be the same as pan bolts,,,I can’t remember .
It’s been a long time,,,I can’t remember if they are 1/4-20 or not ?
I think the pan bolts are larger diameter,,,I’ll have to check myself,,lol .
Tommy
I just went and double checked myself .
The bolts for the pan are 5/16-18 .
The bolts for the windage tray are 1/4-20 .
Here is a pic I just took of one of my sets .
The factory bolt also uses a captive washer under it .
Also,,,,the rusty looking main in that pic is really just one of those red rear main seals,,,,Lol .
Tommy
Tommy
Thanks
I bought it windage tray for my build then I found this ....so if this is any good might build other for a toy
Yea i have a steel crank so might just use that or build the 69 block and save this for something else ...
