Can't figure out passenger side handle
Andre68
San Diego
After painting my car I'm installing the handle and key cylinder back onto the doors. Drivers side went on and worked fine. Passenger side not so much.
I don't understand what could be wrong. I put it on the same way as the drivers side.
My issue: - the handle button does not engage all the way, it doesn't let me push it in all the way, but I can manually pull the bar down that attaches to it on the inside with ease.
The key lock doesn't lock. It's new. When I press down the lock on the top of the door it doesn't stay locked. It just kinda goes down and then up again.
the lock cylinder has a tab for the lock rod-- do you have it orientated correctly-- it might be binding causing this?
also the push button lever same thing -- is the S shape going the correct way?
just a thought since one side works & the other doesn't. Lawrence
Striker post location could be related. If the latch mechanism is in the middle of its travel/operation it wont cooperate.
