74 dart sport
Kameron
The ballast resistor has nothing to do with cranking the engine, LOL. I don't know what you did
Well, there are two wires that connect to the resistor. There is a blue one and a brown one. When in the on position, the blue has a constant 12V, but when it turns over, it drops to .5V. The brown wire has 12V when turning over. When the ballast resistor is connected, the two can conduct electricity to each other, providing a constant 12v to ignition coil whether it is in on or turning over. Since the Pertronix III does not require a ballast resistor, we didn't have the blue and brown hooked together. Once we jumped the two together, the coil had 12V turning over, and was able to provide a spark.
