waggin
moving on ain't easy if you drive a Ford :p
I'm wondering about lifter preload on both of these engines,need to have that with hydraulic camshaft.and just for general information the 360 takes a slightly longer pushrod than a 318 or 340.so I'm wondering if the 360 has the 318 pushrods in it and on the 340 I'm wondering if the edelbrock heads are a lil' taller than a stock head thus needing a longer pushrod to get the preload??? also on the 360 check the slop in the timing chain
Dont mean to steal the thread but I have a stock 360 with a rattle like you described at about the same rpm range with good oil psi cold or hot. Mine is also backed by a 4 speed. I think it may be a wrist pin or piston slap but havent checked into it. Hopefully this will help someone diagnois your trouble.
