bricud
Cuda's Cuda
I recently bought a "69 Barracuda for restoration and one of the first hurtles is to try to get the driver's door open. I have not had it open yet. The car has been sitting for some time so I suspected to find things stuck from rust. I read through lots of threads on this and so far I have removed both driver's and passenger door skin, soaked the mechanism in the door by spraying pb blaster from the inside of the door and through the opening between the door and rear qtr. panel. It has been soaking for a week with periodic re spraying.
I have tried to push the outside button (I can see the mechanism levers moving as it does on the pass. door) and hold it and push, pry, kick, swear, lift and beat with a mini sledgehammer. No help. The door seems hopelessly stuck. I tried prying in different spots on the door, manually work the levers from inside the door, remove the lock rod and make sure it is in the unlocked position, and so on....
One difference I noticed is that on the passenger door (works fine) the only time you can lock the door is when it is shut or you manually rotate the catch. On the stuck door it acts like the door is open as it won't go the locked position. Not sure if that means anything.
A friend of mine offered me the jaws of life to open the door and I am considering it but is there some way to unstick it or hit something from the inside to help things along? Thanks.
