Rob Eppler
My Dart Charger...home made!
I have been reading many posts on this and other web sites about CAP suspension components. I have used CAP suspension products for the past three years. [dynamic strut rods, upper control arms, lower control arms and now the tubular K member] Every time I launch my DART it goes upward about two to two and a half feet, then lands nicely. My point is, after 3 years of running my DART I have had no suspension problems at all! Being a High School automotive instructor I have seen many suspension components go bad from wear. I have my car on the hoist at this time installing a new "K rack assembly" so what better time than now to evaluate the entire suspension system. The upper ball joints, lower ball joints, the rod ends the strut rods and last but not least the WELDS...all components, bar none are not "hurt" in any way shape or form. So some of you who like to beat up on "CAP" maybe you should do more research, and check out others with out putting words in their mouth! The system works and works with out fail! It is adjustable and tough! Now that said, if you think all parts fit with a drop in, I ask you; why are intake manifolds milled to fit??? Why are pistons fly cut for valve clearance? Why are crankshafts drilled and mallory metal added. Point is everything, yes everything needs some work. While you think a crankshaft bolts into your engine and bearing clearance is at .002 to .003 think again! If your afraid of work, stay with the factory fit stuff! It works, but is it what you really want or do you have the ability to massage parts to fit...This is the real question! Nothing and I mean nothing fits with out some work! Do you know where "hot rodding" came from???
Rob Eppler
Automotive Instructor
Monroe Michigan!
Rob Eppler
Monroe Michigan!
