Welcome to the not running the times you expect should run club ! I can't break 13.3 and I know the car should run 12's . Dyno tested 398 hp 413 tq Mahle 10.5 forged Mahle pistons , light port on the stock heads , Air Gap 750 holley street avenger , 8 3/34 3:55 gears stock 340 converter and a Gear Vendors overdrive . 235 60 15 M/T drag radials .
What are your rpm when crossing the line ? I'm at 5300-550 rpm in 2nd overdrive crossing the line .
Going to follow this thread with interest .
jerry6
Stock converter is were you 12 sec pass failed. Go back to your dyno sheet and see what rpm they started the Dyno Pull at. Now, how high does your stock converter stall at............ your leaving a lot of time at the starting line/60 foot mark.
