72 duster with 904/360 magnum..been working fine except it would shift from first to second at like 5mph. Drove it around and all good. Had some radiator problems so it has been down for a bit. Started it up the other day and put it in reverse and it took a second but backed up at idle then stopped. revved the engine up and nothing. Put it in drive and it clunked into gear and moved an inch. Reved it up and no movement. Checked the fluid and it was at a good level but smelled like burnt clutch although still red. Adjusted low/rev band and tried moving the car again and nothing. Been able to drive it around and now it doesn't move. Any ideas.
