Carb choke & throttle linkage
Traikun
Active Member
I'm not quite sure if this is the right spot for this, but here goes.
64 valiant 273 with a blown choke and throttle linkage.
Will a choke from a 65 (I think someone said this carb has a 65 choke pull off on it, so I should be fine with one from a 65), and throttle linkage + gas pedal from a 65 work without modification?
thanks!!
