Engine small block chrysler,850 carb with the following:
prim jet:74
sec jet:82
prim pwr vlv:4.5
idle feeds: .032
sec pwr vlv: blocked off
prim & sec shooter .035
main air bleeds: .036
idle air bleed:.075
the low down--I have a/f meter at idle-12 afr normal drive thru gears never goes above 13 afr--problem-when I stick the throttle(pedal to floor) the afr hits 20 (very lean)sputters the recovers and pulls like a raped ape-This is ONLY happening under full hard accelerating like a run down the track help me out please!!!!!!!!!! DO i need to reduce main air bleeds to richen up mixture under hard accelerating???????? Thanks Steve
prim jet:74
sec jet:82
prim pwr vlv:4.5
idle feeds: .032
idle air bleed:.075
