camd64
Remember Landy
so here is my problem, my carb. (1406 edelbrock) runs really rich at idle and just off idle. I have checked all the stuff I can think of and can't seem to figure the problem out. I have the insulator gasket, the choke turns off when it is warm, fuel lines are away from heat, fuel pressure at 6psi, and i am 1-1/2 turns out on the mixture screws. what am i missing? I tuned the idle with a vacuum gauge then after test driving it felt lean so i stepped up one rod size to the 73/42 and a size down on the spring to a 4'' (yellow). that seems to help a bit with the lean kinda stumble off the line but now I wonder if the rods have anything to do with the idle circuit? any carb. guys got any ideas?
