Carb hook up/ Pcv question.
StickweldinSteve
Notth Carolina
I have a pcv on each valve cover one is just a simple L and one is a push in larger filter style. I’m installing a new carb. A Edelbrock 650 avs2. Will it hurt anything to T both pcv’s together and run into the front pcv spot on the carb or should I run one to the front and one to the rear? Friend of mine is telling my to just plug one pcv saying I only need one.
Also Do I have to run a fuel pressure regulator?
Thanks for the help.
This is something I've also wondered about. I stand to be corrected by much more knowledgeable people on here but I thought a PCV valve uses engine vacuum to suck excess fumes back into the engine to be burned off. If you hook up two, do you possibly start to suck oil back through the engine as well by creating too much PCV ??
Pcv on one side breather cap on the other. Don't run 2 pcv valves.
I think what threw me is when I went in AutoZone what I have was called a pcv breather on their packaging. I plugged in a regular breather cap though no lines coming out Thanks man.
I think what threw me is when I went in AutoZone what I have was called a pcv breather on their packaging. I plugged it with a breather cap though. Thanks man.
The breather is the inlet for the pcv system. For it to be dead correct, it really needs to connect to the air cleaner with a hose. Here is a proper PCV system.
My original 340 air cleaner housing has the breather tube fitting in the side, thus not filtered air. Since there is filter material in the part that pushes into the valve cover, guess it is not a big deal.
Lots of GM products were the same way with a small extra filter within the filter.
