Carb identification help
roger.
Member
WA
Hello, everyone. New to the forums. I've spent about a week trying to identify this Holley carburetor, but I have had no luck. I've tried searching these forums and over at /6.org as well. The best information I've come by is that it could be an economical carb, maybe even used on farm equipment.
The reason I'm trying to ID the carb is I want to rebuild it and put it on my '67 Barracuda that has a stock /6. I have an aluminum 2 bbl manifold waiting for it. Plus, it gives me something to do while I'm stuck in my room because of a broken ankle. I've attached some photos of the carb. Hopefully they are good and clear enough.
Any help or information would be greatly appreciated.
Welcome to FABO. It looks like a 1977 Dodge truck 400 2 barrel.
Check the bolt pattern against the manifold before rebuilding, it looks like the big bolt pattern 2bbl.
Thank you for the, gentleman or gentlewomen. I appreciate it. May I ask how you knew it may be the 400? I'm just curious in case I run into a similar situation.
I also have checked the bolt pattern on the manifold and it mounts fine. Thank you for the advice though. It would not have been fun to rebuild the carb only to have it not fit the manifold.
I have not check Mike's Carburetors yet, but I will. Thank you.
