fnaramore
POWEEERRRRRR
Got an interesting one for you guys today, completely stumped the edelbrock carb techs. So put a 1405 eddy on my 318 yesterday and was tuning it and noticed occasionally it would make a sound such as if you were sucking the last little bit of drink using a straw. Happened maybe every minute or so and lasted for about 5 seconds. When this occurred it had NO effect on the engine running. ZERO drop in vacuum or rpm. Only thing that happens is you can hear the sound and feel a slight vibration in the vacuum gauge if you are holding it. The sound goes away if you slightly cover the choke plate with your hand (which is gone, i removed the choke entirely but the tech said thats not the issue) or if you give it some throttle. Tuned the carb no problem and she is running very happily, just curious what the sound it. Thanks in advance!
