Hanging up like that is usually caused by the transfers still feeding fuel or there is still a vacuum signal going to the distributor.. Primary t-blades may be way too far open.Remove and block the advance hose. If no change,take carb off engine. Make sure choke is off.Close t-blades all the way by backing out curb idle screw. Turn screw back in 1.5t or until transfer slots under the blades are square or slightly rectangular(remember this initial setting). set mixture screws to about 1/2 t from lightly seated.Make sure secondaries are closed but not sticking.Put carb back on.Fill it with fuel.If mechanical pump,I fill bowls through vent pipes. At least 50cc per bowl.Block vacuum advance. Put Fast-idle cam on 2nd highest step.Start her up.If she fails to lite off, squirt a few ccs of fuel down each primary and retry, again on 2nd highest step.Let her warm up.Try to keep rpm between 1500 and 2000. While warming up check fuel levels if you have sight-windows, or plugs. Once warmed up, see if she will idle at the initial setting.If she idles a little slow turn the curb idle screw in a bit,up to about an additional 1/2 turn. If she idles way too slow and its not flooding, here are the most likely reasons; A)Insufficient idle timing, B)Vacuum problems;maybe she wants bypass-air, C)incorrect float level, D)incorrect valve adjustment......An easy way to set Idle Timing is to check the cam card for the intake @.050 duration. Just divide that number by 15. eg 220/15=15*. No card;guess.Idle timing is not rocket science. You can work with almost anything between 10* to 20* at this point....... Bypass-air is just drilling the t-plates. If you suspect she wants some, prove it by introducing air at a vacuum port, such as the PVC port or the brake booster port. Just feed her a little bit at a time. If the rpm rises, there you go, bust out the drill bits........Once you have a satisfactory idle rpm, you can fine tune the mixture screws, and reattach the advance hose to a "ported" source. If the mixture screws still dont work, the circuit may be faulty. The above has worked for me with cams in the 200* to 240*range.If you get lost, just go back to the very 1st sentence.Finally dont forget to limit your maximum advance to something like 34*+/-2. I always run a vacuum advance on the street.It makes a ton of difference in driveability, esp with a stick car.
