I'm not a guru on which ones were used which years. Some had a small hole off to the side for vacuum supply and some did not. I would "assume" that the later models did, but assumin gets me in trouble a lot. I bet @slantsixdan will know for sure which one it takes and can give you a supplier for a good gasket. I tagged him, so maybe he'll let us know.1984 Dodge Ram D100 225 1bbl. What is the best Carb. mounting gasket? Don't see much out there anymore. Thanks
| Brand | Part Number |
| Chrysler | 4071983, supersedes 3698360 |
| Detroit | 35025 |
| Engine Seal | 85411 |
| Fel Pro | 60274, 13-1050 |
| Mahle | G25456 |
| McCord | 66-0143 |
| Rol | CM55015 |
| Victor Reinz | G25456, 711428000 |
| Walker | G966 |
