[WANTED] Carter 1bbl
Henchman
Rating - 0%
0   0   0
I’m looking for a refurbished to factory specs carter 1bbl for my 1965 valiant
I so tired of screwing around with these old POS carbs I have.
does anybody here do quality work refurbishing these carbs or know a reputable place/ person who does?
I moved to a weber 2 barrel
Saved a lot of trouble
Only issue is kickdown
Probably go with a Lowcar cable set up
Where are you?
That’s pretty sweet, is that a Holley progressive?
I just need something to get me through the summer, this winter the car is coming apart for paint/ interior/ top/ v8 and 4 speed. I’ve rebuilt the carb and messed with it so much I’m just over it. I just want to drive the damn thing!
I found a good carb guy and he rebuilt my 1bbl carb off my 69. It would have been cheaper to get a new one, but it was only 300 bucks to rebuild it. He does test his rebuilds on a motor
I have a Carter carb for a slant 6 for 62-63. It looks to be in very good shape and appears to have been rebuilt. It has never been used and was supposedly on the shelf of a parts house when I bought it. I still have the original description from when I purchased it. Its been sitting on my shelf waiting for a good home.
I did not use it because I had my original Holley rebuilt to keep the engine original on my 63 Valiant.
I did not use it because I had my original Holley rebuilt to keep the engine original on my 63 Valiant.View attachment 1715900577 View attachment 1715900578 View attachment 1715900578 View attachment 1715900578 View attachment 1715900579 View attachment 1715900580 View attachment 1715900581
Thank you for the response. I took mine apart and the throttle shaft was like .005” big
I checked my other two and they were the same. I got out some brass and my chucking reamers and was going to machine some new bushing and attempt to repair it then I checked e-bay and one had come up for sale that had been already rebuilt.
I bolted it on yesterday and drove out to firebird raceway to watch the test and tune and the car ran perfect!
Thank you again!
