Carter AVS CFM ratings ?
rustytoolss
Clinton, Ohio
Does anyone have a list of the carter AVS CFM ratings that would have the carb numbers, along with the primary sizes & secondary sizes ?
Something to keep in mind about "numbers." I believe Holley published numbers "dry" and Carter published "wet" which means that a "given number" between the two brands means that Carters acually flow more than Holley
Also, remember that even Holley is not consistent. Holley 2bbl carbs are rated at (I forget) I think 3" Hg vacuum, 4 bbls at 1.5 Hg. This means the (in) famous Holley 500cfm 2bbls "aren't" 500 cfm, that is. More like 350 compared to a 4 bbl.
OK, lets try this a different way. What would be the smallest AVS ? Would it have been on a 340/ or a 383 ???
Or for that matter what about the smallest AFB. probably on a 273 ???
Carter AVS
First installed on the 1968 Mopars
CFM Rating--------Primary - Secondary ----- Venturi --------Primary Jet - Secondary Jet --------Engine
625 CFM ............... 1.563" x 1686" ........... 1.186" x AV......... .089" ........ .095" ................. 340 {1968 thru 1970}
625 CFM ............... 1.563" x 1686"............1.186" x AV ......... .089" ........ . 092" ................ 383 {1968 thru 1971}
750 CFM ............... 1.686" x 1686" ........... 1.437" x AV......... .101" ......... .095" .................440 {1968 thru 1971}
There were only "so many" AVS's. Smallest engine (68?) they were used on is a 340 and generally, in 71, Ma switched to Thermoquads
The 273 AFBs, as well as the earlier engines in general, even the 426s, were a competely different carb. The mounts were different and the air horns were smaller diameter. That is, earlier 4bbl air filters won't interchange.
Carter AVS
The above specifications are for both Manual and Automatic Transmission cars, except for the 340 Automatic.
Note; The Secondary Jet size for the 340 Carter AVS 'Automatic Transmission' cars was .098".
That is why they ran so well.
