[WANTED] Carter Carburetor choke Adjustment screw!
LovetheA's
Fairfield, CT
Looking for 2 choke adjustment screws that would work on my 67 dart and barracuda. Both for 67 383 manual tranny cars. I believe the correct carb is a Carter 525 CFM model 4298S. I don't know if the adjustment screws worked universal across most Carter carbs? Looking for screws that are in nice shape, straight, and not bent or stripped. The screws I have are slightly damaged.
Carl
You mean the idle fuel mixture screws? The two on the front with the springs?
Sorry everyone I should of been more specific. I'm looking for the fast idle control screw that controls the idle control mechanism upon warmup. I need two one for each carb. I can post pics if need be.
Carl
Should be something simple like an 8/32 or 10/32. Unless you're going for the concourse resto, a good hardware store should be able to hook you up.
Ask Tony he helped me out on some Thermo Quad stuff. He may have some other Carter stuff as well. His board name is whitepunkonnitro
