Carter Carburetors ~ Tech and Specs
Carter Carburetors
1968 Plymouth/Dodge ~ 383/335 HP ~ 383/330 HP ~ 383/300 HP ~
AVS {#4426S; Manual}
Rated @ 630 CFM's
Throttle Body Sizes ......... 1 7/16" x 1 11/16"
Venturi Sizes .................. 1.186" x AV
Primary Jets ................... .089"
Secondary Jets ............... .092"
Metering Rods ................. 16-164 {.065" x .060" x .053"}
The same combination was used for the 1969 Plymouth/Dodge ~ 383/335 HP
as well as the 383/330 HP.
AVS {#4615S; Manual}
Rated @ 630 CFM's
Carter Carburetors
1969 Plymouth/Dodge ~ 383/335 HP and 383/330 HP
AVS {4616S; Automatic} or {4682S; Automatic}
Rated @ 630 CFM's
Throttle Body Sizes ........... 1 7/16" x 1 11/16"
Venturi Sizes .................... 1.186" x AV
Primary Jets ..................... .089"
Secondary Jets ................. .092"
Metering Rods .................. 16-165 {.0635" x .060" x .053"}
Carter Carburetors
1967 Pontiac ~ 326/285 HP 'HO'
AFB {#4246S; Automatic}
Rated @ 575 CFM's
Venturi Sizes .................. 1.186" x 1.563"
Primary Jets ................... .090"
Secondary Jets ............... .083"
Metering Rods ................ .065" x .060"
Carter Carburetors
1968 Plymouth/Dodge ~ 440/375 HP
AVS {#4428S; Manual} and {#4429S; Automatic}
Rated @ 750 CFM's
Throttle Body Sizes ........ 1 11/16" x 1 11/16"
Venturi Sizes ................. 1.437" x 1.586"
Primary Jets .................. .101"
Secondary Jets .............. .095"
Metering Rods {4428S} .. 16-176 {.067" x .065" x .055"}
Metering Rods {4429S} .. 16-575 {.065" x .062" x .053"}
The same combination was again used in 1969.
* {#4617S; Manual}
* {#4640S; Automatic}
Bosco Joe,
I'm not an expert on the Pontiac GTO 'Tri-Power' Carburetors.
The Rochester 2-Barrels with the 1 1/4" Flange-Base and 1 7/16" Throttle-Bore sizes with the following Venturi size;
* 1 3/32" ..... 278 CFM
The Rochester 2-Barrels with the 1 1/2" Flange-Base and 1 11/16" Throttle-Bore sizes were rated as such with the following Venturi size;
* 1 3/16" .... 249 CFM
* 1 1/4" ...... 269 CFM
* 1 5/16" .... 299 CFM
* 1 3/8" ...... 308 CFM
By most calculations, the 1964 and 1965 ~ 389 'Tri-Power' combinations
were rated at 767 CFM's.
The 1966 - 'Tri-Power' combinations were rated at 836 CFM's.
The last Pontiac's to utilize a Carter AFB.
1967 Pontiac ~ 326 'HO' ~ 285 HP
* #4243S; Manual
* #4246S; Automatic
Rated @ 575 CFM's
1967 Pontiac 400/325 HP
* #4242S; Automatic
Rated @ 575 CFM's
1967 Pontiac ~ 400/333 HP and 400/350 HP
* #4243S; Manual
* #4242S; Automatic
Rated @ 575 CFM's
Carter Carburetors
1966 and 1967 Plymouth/Dodge ~ 426 'Street Hemi'
AFB {#4139S; Front Carburetor}
AFB {#4140S; Rear Carburetor}
Rated @ 600 CFM's
Throttle Body Sizes ................. 1 7/16" x 1 11/16"
Venturi Sizes .......................... 1.186" x 1.563"
Primary Jets {Front Carb} ........ .089"
Secondary Jets {Front Carb} .... .1065" {Left Side} ~ .089" {Right Side}
Primary Jets {Rear Carb} ......... .089"
Secondary Jets {Rear Carb} ..... .080" {Left Side} ~ .083" {Right Side}
Metering Rods {Front Carb} ...... 16-341 {.0685" x .059"}
'RO' and 'WO' Super/Stock Packages
Note; These Carburetors were 'recalibrated' at the Factory
AFB {4139S; Front Carburetor} and {4140S; Rear Carburetor}
Rated @ 600 CFM's
Throttle Body Sizes ................... 1 7/16" x 1 11/16"
Venturi Sizes ............................ 1.186" x 1.563"
Primary Jets {Front Carb}........... .101"
Secondary Jets {Front Carb} ...... .083" {Left Side} ~ .101" {Right Side}
Primary Jets {Rear Carb} ........... .101" {Left Side} ~ .083" {Right Side}
Secondary Jets {Rear Carb} ....... .101"
Metering Rods .......................... .070" x .047"
Low Speed Jet {Front Carb} ....... #65 {.028"}
Low Speed Jet {Rear Carb} ........ #65 {.028"} Manual Transmission
Low Speed Jet {Rear Carb} ........ #65 {.031"} Automatic Transmission
Power Piston Spring ................... Orange
Note: The Carter AFB's {#4139S and #4140S} were advertised as being rated at 625 CFM's.
Note; The 'adjusted' rating was {-4%} less than the 'advertised' rating.
Note; The above 'calibrations' were set only for the 'RO' and 'WO' Super/Stock packages.
Carter Carburetors
1968 Plymouth/Dodge ~ 426 'Street Hemi'
* #4430S {Front Carb}
* #4431S {Rear Carb; Manual}
* #4432S {Rear carb; Automatic}
Rated @ 600 CFM's
Venturi Sizes .................... 1.186" x 1.563"
Primary Jets {All}............. .089"
Secondary Jets {#4430S} . .080"
Secondary Jets {#4431S} . .092"{Left} ~ .077" {Right}
Secondary Jets {#4432S} . .092 {Left} ~ .077" {Right}
Metering Rods {#4430S} ... 16-341
Metering Rods {#4431S} ... 16-543 {Left} ~ 16-544 {Right}
Metering Rods {#4432S} ... 16-543 {Left} ~ 16-544 {Right}
Pelican-Man,
I'll post that information. Very surprisingly, but the Rambler 290/225 HP
had a larger CFM-rated Carter AFB Carburetor than the Mopar 273/235 HP.
1967 Rambler 290/225 HP
#4252S
Factory listed rating @ 570 CFM's
Throttle Body Sizes ...... 1 7/16" x 1 11/16"
Venturi Sizes ............... 1.062" x 1.562"
A large Secondary Venturi.
Rambler stated in the 'Brochure Specification Sheet'.
The 'high-flowing' Carter AFB {570 CFM's} on the 290/225 HP 'N-Code'
Rambler out-performs the 'smaller' Carter AFB found on the Plymouth and Dodge - 273 High-Performance engines.
Anybody know the metering rod size for the 3854S? This thread includes all specs except for that one :-). Thanks!
